Add SBC option missing under SIP Trunks in 3CX v16
ecris
Forum User
I'm trying to install a Session Border Controller, which needs a key from the 3CX system, but if I go to SIP Trunks in the system, there is no such option. The documentation mentions adding the SBC under SIP Trunks, yet I can only add a trunk or a gateway.
How do I set up an SBC on 3CX v16? I assume something has changed since the documentation was written.
Is your PBX up to date V16 SP2 ? key has been added since V16 SP1
Do you follow SBC docs for latest V16 SBC ?
Reactions: ecris
As above you need V16 SP2, if you click on Update within the management console you will see if your system needs downloading the update
Reactions: ecris
Thank you. I am installing it now.
I did not install this update earlier as it showed as a Beta update earlier, but I see it is showing as Release now.
Reactions: AWS2P
fcentral
