Adding a new non geographical number to the 3CX local PBX. Number not provisioning.
chrislindsay72
Hi Guys,
Pleased to be a part of the 3CX forum!
I have an issue from a non geographical number I am trying to add to the PBX
voip.co.uk has allocated a non geographical number 0330 *** ****.
I have added this to the 3CX portal to the DID's tab as *330 *** ****
I have also created an inbound rule and there is also a default outbound rule for voip.co.uk.
When I call the number I just hear 3 beeps.
There is nothing in the logs....
Is there some trouble shooting I could conduct to understand where the issue is occurring..
Chris
Need to clarify to the setup.
1. Is the 0330 number a sip trunk, and have you configured a sip trunk within 3CX and is the sip trunk registered and status light is green.
2. If the number is a ddi number associated with another sip trunk , does the sip trunk main number work
Have you check the event logs , to see if you can see the incoming call/.
Hi Saqqara
I have an error messgae in the logs
Call or Registration to 03301647005@([email protected] - UK) has failed. 193.203.210.38 replied: 404 Not Found; from IP:193.203.210.38:5060
12/23/2020 2:47:06 PM - Call to T:Line:10000>>03301***005@[Dev:sip:10***[email protected]:50*0] from L:416.1[Extn:116] failed, cause: Cause: 404 Not Found/INVITE from 193.2**210.38:50**
Sorry to add
I think I have just added the number to an existing SIP trunk. The light is green and the main trunk number is working correctly
Chris
On the one your provider added that number ?
Do you have a mgt console on sip trunk provider side to see if that number is really enabled and associated to the trunk ?
Are the beep coming from your trunk provider?
Just received a answer to my question from the provider. Ofcom needed to allocate the number to my provider which may probably be the issue!!!
Thanks for all your help, I though I was going mad!
BR
Chris
fransisco
