Adding feature button on Avaya phones
jguh
Trial User
Is there a way to add more than call appearances line on the deskphone?
I'd like to add for instance auto dia button or call fwd function etc...
Thanks!
Hello @jguh,
Please note that Avaya phones aren’t supported by 3CX, so features like extra line appearances or auto-dial buttons can’t be configured reliably.
For full compatibility, we recommend using a 3CX-supported phone, please check the supported SIP phones list here https://www.3cx.com/sip-phones/
Well noted @AbdullaR_3CX, not supported won't automatically means not functional ;)
Thus I was trying to make it work as SIP is a standard, it could be an option, I thought.
With many many legacy Avaya phones (more than 9 000), it would be great to customize a bit more with standard telephony features and keep some on the 3CX environment :)
@jguh In the list you can see some Legacy devices you can use but still there a lot of limitations for those devices. Check also below:
• https://www.3cx.com/sip-phones/avaya-ip-phone-provisioning/
I read that one too... Thanks for sharing.
I understand that no clue than "not supported" on my query ;)
I can use those basic telephony features with dial codes... pitty to not be able to add button but as there are not supported... fair enough I will ask my user to use web page rather than legacy deskphones :)
Reactions: NatalyS_3CX
You can use the Web Client, PWA or the new V20 Softphone as well.
Reactions: Evolute IT and jguh
Reactions: jguh and Evolute IT
x1515
