- Joined
- Aug 25, 2021
- Messages
- 18
- Reaction score
- 3
I have an existing SIP Trunk with existing DIDs in it, everything works fine.
I am adding more DIDs.
Even when I add just one new DID and click "OK" it will auto take me to the "Options" tab.
Once on the "Options" tab, I am NOT able to click "OK".
If I click "cancel" my new DID does not get added.
I am not sure if it wants me to make a change inside the "Options" tab, it's not obvious to me.
TIA
Edit:
[18.0 (Build 461)]
I have 8 existing DIDs and am trying to add a 9th.
Edit:
I am adding it in the correct format "Please note that Telnyx sends incoming numbers in the E164 format (e.g +13012345678) so add your DIDs in the same format to avoid call routing issues."
Edit:
I tried opening the portal in incognito mode just to make sure the browser wasn't causing issues, still didn't work
TIA
Edit:
[18.0 (Build 461)]
Edit:
Edit:
