Solved Admin console issue after v20 upgrade
IIDF IT
Hi!
I've tried to upgrade to v20 yesterday.
Everything was fine until I tried to open Admin console.
I logged in as System owner and see Admin button in left down corner.
But if I press, it I can only see admin UI for a moment and than it is closed immediately.
So I rolled back to V18 snapshot.
No ip restrictions are set.
Any ideas how to fix this?
Best regards, Alex
This require to be checked with logs as well.
May i ask, is there any custom template in the installation?
Hi!
Not sure about custom template, but I believe it's just default installation.
Any way to check this?
Should I examine nginx.log or any specific 3cx logs?
Try to replicate while your browser is in dev mode and see if there is any error.
Otherwise we will need to check this with a support ticket.
Ok, I reproduced the problem and enabled nginx access.log
Now every time I press Admin button, I can see in access.log
[01/Jun/2024:22:20:21 +0300] "GET /xapi/v1/Backups/Pbx.GetBackupFailoverSettings() HTTP/2.0" 403 0 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/125.0.0.0 Safari/537.36"
The only xapi location in nginx log is
location ~ ^(/xapi/v1/Report|/xapi/v1/ChatHistory|/xapi/v1/ChatMessages)
Didn't found any info on BackupFailoverSettings
Is it possible to create a support ticket to check this further?
not ready to pay for this yet )
You may also contact with your partner.
So we performed clean install, restored from backup.
Than moved records with rsync and switched to new server.
Everything seems to work fine.
Glad to know this is resolved.
amazingbv
