Solved Airpods as a Speaker not Working
Gilroy
Hi Team,
Hope you guys are doing well.
We're experiencing an issue wherein when we try to set Airpods as the speaker and microphone(WebClient and Desktop App) which is paired on PC, it doesn't have any audio. But when we use other headsets like Jabra, it was perfectly working. Airpods are working last week, however, it doesn't seem today.
3CX Version: 18.0 (Build 314)
Hosted: AWS
Steps Taken: Restarted PC, Re paired the Airpods to the PC.
Hope you could help me with this. Many thanks, 3CX Community!
Do they play other sound through the PC?
Hi @Gilroy,
Ensure that the airpods are being used in Hands-Free mode as you should see them appear as Pro Stereo and Hands-Free. If you use them in Pro Stereo then you won't have any mic / audio usable. Make sure that Windows and 3CX are using them in Hands-Free mode by default.
Reactions: SweetAction
Hi @kieferschild, the customer mentioned that they can use it on Teams without any problem.
Hi @VasilisV_3CX, I'll relay this info to the customer and let you know of any updates. Appreciate your help!
Reactions: VasilisV_3CX
Hey Team, just letting you know that the AirPods are now working with @VasilisV_3CX solution. Many thanks!
Great to hear @Gilroy! If you need anything else, feel free to open a new thread!
