Alcatel 8088 BT Smart Deskphone integration to 3cx PBX
maxmm11
Hi all
is there is any XML file to provision This phone Alcatel 8088 BT ?
I very much doubt you will find an xlm provisioning file for this phone
You will have to manually config the phone with the required details to connect to 3CX
if i did this i will be able to use the speed dials keys ?
Not familiar with this phone, so you would have to experiment and test the keys yourself. If you can program speed dial numbers, etc I do not see it being an issue
As it is 3CX unsupported phone nothing can be certain. The basic functions will surely work, but it's not so sure for advanced functions.
Wecare_ITA
