  • V20 Update 10 Final Learn more
Alcatel-Lucent M7 Enterprise Deskphone
IRISIT
We have a client who recently moved to an Alcatel Rainbow Hub system which involved the purchase Alcatel-Lucent M7 Enterprise Deskphones. They are extremely unhappy with the overall functionality of the system and have asked to provide a quote for moving to 3CX, however they do wish to purchase new handsets.
Their Alcatel-Lucent M7 Enterprise Deskphones are not listed under supported 3CX phones.
Can these phones we used with 3CX.
Thanks in advance for any help.
Regards
Robert
If they are SIP compatible, yes - but you would have to set them up manually. Check whether they are SIP devices and you can then use a Trial key to verify. It is possible that any advanced functionality may not carry over even if they can be registered for calls.
BConveryCoreCare
