Allow outgoing number list
Alle CTEC
Hi everyone, I have a 3CX Cloud customer who requires this feature. A list of extensions should be able to contact a list of numbers. Is it possible to populate a list, or do I have to create an outbound rule for each phone number?
Thanks.
You can just create one outbound rule and use a comma for additional numbers in the prefix
Yes, this is clear to me, but if anything, it was possible to create a list with some comments to remember the ownership of the number
You can name the outbound rule whatever you like.
@Alphabetics
The list of numbers is limited however I have divided the list into 3 rules
This can only be limited with the outbound rules where you can add specific extensions to the allowed list.
If those extensions are also part of specific Departments you may also add only Departments.
In 3CX this can only be achieved using outbound rules. However, I wouldn't recommend creating a large number of them, as you also need to define each rule for all relevant number formats (E.164, national and international) to ensure reliable routing. A better approach is to place an SBC, such as AudioCodes or Anynode, in front of the 3CX and handle the routing there.
Hi, can you explain more? The phones in question are currently configured as SBC routers to the 3CX cloud switchboard.
Thank you
Thank you
Hi, yes, I'm not referring to the 3CX SBC or Router Phones. I'm talking about a real Session Border Controller (SBC) for SIP routing.
You can configure an SBC as a SIP trunk and route your calls through it. The SBC allows you to control, route, reroute, or even modify outgoing (also incoming) calls before they reach the provider (or pbx). In a way, it lets you act like your own SIP provider.
SBCs are usually quite complex to configure, but in many scenarios they are the only practical solution if you need full control over outgoing call routing.
Reactions: fxbastler
Excuse me, are you telling me that I could apply the call filter directly to the SBC, therefore the list of allowed numbers, right? Is there a guide on this? Thanks.
  • Sad
Hi, no. I'm referring to a separate product that you would need to deploy in front of your 3CX. Take a look online at solutions like Anyode or AudioCodes to see whether running an SBC in front of your 3CX is a viable option for your environment. You can then route all outgoing calls through the SBC and apply your routing logic there.
That said, your question gave me another idea: some IP phones support their own local outbound dialing rules. It's not the most elegant solution and can be cumbersome to configure and maintain, but depending on your use case, it might work. Personally, I would still recommend using an SBC if you need this kind of control.
Reactions: fxbastler and bitn2
So, I can't use a 3CX Debian SBC, for example?
  • Sad
Reactions: bitn2
no. that's not a sbc like these ones i talked about.
Sorry, via SBC Audiocodes it is only possible to use phones or even Windows Desktop Apps and Smartphones
Are there anything else you can use? Phones, softphones and mobilclients is everything... Or i didnt understand you?
Sorry, I meant to say if I use an SBC audiocodes through it can I record DECT landlines etc. or even desktop and smartphone applications?
The features of your 3cx doesnt change. So yes, you can record calls like before.
The device is being proposed to me to place restrictions on the recipient numbers. This means that a pool of extensions will only be able to call a specific list of numbers. Currently, if I use 3CX SBC Debian, I can only route traffic from DECT landlines, etc., etc., not from applications. Is it possible to route traffic from applications via SBC Audiocodes, or just from phones?
I'm not sure if you've read all the posts... The SBC is integrated as a trunk, so all calls go through it, regardless of where they originate.
Wait a minute. I currently have a Debian 3CX SBC and only the landlines go through the SBC. The PC and Mac applications and smartphones register directly on the 3CX switchboard.
amazingbv
