Allowed Country Codes whitelist
Artur.O
Hiya, I have a question if there's a way of whitelisting extension so it bypass Allowed Country Codes and can call any number around the globe? I need to whitelist directors and have limits for other people. Thanks
No you'd have to be more restrictive on your outbound rules and have your allowed country codes enabled.
Set up some extension groups and use those.
The country codes are system wide on/off. You can use your outbound rules to limit what number length the users of a group can call, and have another rule on top that is specific to your directors that gives them more access.
I would not recommend to enable all countries, but rather the ones your directors intend to use if possible.
martin99
