Analogue PA system
Brad Webb
Platinum Partner
Has anyone connected an analogue paging amplifier to a 3cx? Currently we have an Adastra PA amplifier which is connected to a paging port on the old PBX.
I would like to disconnect the PA system from the old PBX and connect in to the 3cx and I wondered if anyone has had any experience with this before?
I am assuming I would need an FXS adaptor with auto answer enabled?
The end result would be for a user to dial an extn number or code to page through the PA system from their desk phone or web client
Thanks in advance
I know there are devices such as the Snom PA1 which can intergrate a PA Amplifier in.
While the PA1 is an excellent device, more typically you would use an analog FXS gateway. The gateway connects to 3CX over SIP, and connects to the paging system via analog. You don't really need to do anything special with the gateway in terms of "auto-answer" because the paging system is configured to auto-answer. Your gateway will be assigned an extension that your users can dial. When dialed, the user will typically hear a beep indicating the paging system is ready for them to speak. With a supported gateway, this should be fairly easy.
It is really going to depend on what the input to your Adastra PA amplifier is. If it is a phone line input then , yes , you could connect an ATA. However, if it is a low level audio input, then you are going to require some sort of interface between the phone line and the PA amp. This could be as simple as a transformer, capacitor and some resistors, but may require a device such as this...
https://www.xorcom.com/product/ip-pbx-public-address-system/
If you do a web search, you'll probably come across similar devices.
bosdorf
