Android App: Continuous Registration and Integration Improvements
  • Thread starter Thread starter GiannosI_3CX
  • Start date Start date
GiannosI_3CX
A new update for the 3CX Android App is available for download on the Google Play Store. Continuous registration has been added along with improvements on image sending via different messaging facilities.
Keep on top of calls​
“Keep Active” functionality has been introduced providing the option to stay registered so that a c...
Where is version 18? It's still the 15 version in the PlayStore
The current version on PlayStore is 18.0.3. What's the Android version of that device? Please note that the app is not available on devices running Android less than 8.0.
Reactions: N_G
Hi @Achille F , thanks for your feedback.
"Keep Active" feature designed to be deactivated when device switched off and/or app forced to stop. It was designed like that due to the fact that this functionality costs battery consumption, so should be activated only when user is aware of it. On the other hand, long running processes, especially on device start up, are not suggested to be automated on android.
Reactions: jed and Achille F
Keep alive feature is only needed on bad networks where Google push is blocked. So you should only use it now and then and but by default. If your WiFi in the office is blocking push it's better to fix it at that level...
@Nick Galea Thank 3cx team so much. Now china 3CX fans could enjoy the world best cutting edge soft phone,we keep waiting for this for so long. Now dreams come true.
Thanks again.
Are there any plans to bring 'Keep Active' to the iOS version of the APP?? I have significant need of this as it is the only thing allowing us to use the 3CX mobile App with our intercom server on a closed network..
@Nick Galea
sherry reynolds
