Another beginner question - number of Sip Trunks and incoming numbers
docsport
Hi again,
I am still going through the help (the German help, of course) and it says in the datasheet "maximum 10 users" and "Number of Sip Trunks </= 6". Ok, we have a Sipt Trunk with 2 voice channels and 2 numbers but in the German forum they wrote that this is a bit of misunderstanding and only one number can be reached from outside.
There are many people thinking that the can be reached from more than one number but it seems not to be true.
So my question is it possible to be reached from outside with 2 numbers or only one.
Thanks for clarifying and have a nice weekend
Carsten
2 channels on the trunk means 2 active calls. The numbers (also called DIDs) have nothing to do with the amount of calls.
It might be easier to explain what you're trying to do, as it's not super obvious (probably lost in translation.)
@ConceptsWeb Thank you for the fast reply, to clarify, we are 2 people with 2 numbers and
I am trying to find out if I can be called on both numbers from outside or only on one.
Thank you so much
Thank you so much
Depends on how you route each number. They can be assigned directly to extensions, or go to a ring group and then the number would ring all users of that group. You can also use IVRs.
This is not the point of the post. The user mught upgrade to SMB to have multiple DIDs. They just wanna know about routing.
My wish was to assign the number directly to extensions, so that you can call 1234 and end up with person A, and if you call 5678 you end up with person B. But I think @SteveITS gave the answer. Thank you all again and have a good weekend
You can do that. Just upgrade to SMB (the paid hosted one), and you'll be able to use more than 1 DID, and route them to each extension.
Yes the limitation is in the Free version.
DejanMDS
