Solved another rule on friday at certain time
bit101
our customer has from monday - friday business hours from 07:00am - 05:00pm. After that the IVR shall get an response that the company is closed. But from friday at 05:01pm - monday 07:00am the calls shall forward to another internal number. How can we this realize?
thanks & regards,
beon
You need to explain more in details your call flow, is it one main number alone who needs to be forwarded? where is it going ? on Q ?, RG ?, single extension ?
instead of IVR , perhaps use a fake extension to forward to IVR "closed message" and add exceptions same extension to send elsewhere during weekends.
Hi aws2p,
yeah that seems to be the solution, thanks!
But works this also for all incoming calls from the external?
The Rules are global for all external incoming calls
And what number have i set in the exception? I cannot set the "*" sign for all numbers the externsions -> exceptions
Hi together,
it works problem solved, many thanks! :-)
EMMEPICASA
