Solved Archived recordings
GH-JD
I know there is an issue with recordings being archived at the moment, is there an ETA on the update to fix it?
The recordings which do get archived, mostly outbound - the format of the file name has changed from having a "%" between the first and last name of the user to just have a space.
Is this change permanent?
Cheers
Matt
Hi @Matthew_Harrison,
This was investigated and there will be a fix on the way shortly.
Hi, I am running v18 Update 2.
Yes, I double checked and edited my response, a fix is on the way and will resolve the issue shortly.
Same here, we need this fix before U3.
Hi @Joseph D. Sileo & @ConceptsWeb,
While I can't give you a solid ETA, I can tell you that it is on the radar. As always, keep your eyes peeled on the blog and forum for more updates.
WAFI
