Audio Delay during call
Gav
I'm still battling an issue we have with our Fanvil phones...
At the start of calls, users experience a brief loss of audio.
Sequence of events -
  • User dials a number
  • During the ringing stage there is sometimes a brief loss of audio
  • When phone is answered, first second or two everything is fine, then loss of audio for around a second
  • After that call is rock solid
Things I've discovered...
  • Does not affect 3CX phone client
  • Does not matter which model of Fanvil (we mostly use X4)
  • Does not matter if call is internal, external - audio glitch is experienced at all times
  • Changing codec makes no difference
  • I've tried plugging the phones into their very own switch to eliminate any kind of traffic congestion
  • Example of Wireshark capture shows this loss of audio. Delta of 1030ms. Max Jitter of 110. There is a lot of odd >1000ms delta errors in the capture, almost of regular intervals...I'd love someone to shed some light on this. Capture attached - rename file to .pcap to open it.
  • I've tried a multitude of settings on the fanvil phones. Nothing has any effect.
  • I'm convinced this isn't network related or QoS. Simply by the fact I can replicate this issue on a 1Gbps switch with only two phones connected (and obviously a connection to the core LAN for access to 3cx server).
  • This problem is near enough identical to this - https://www.3cx.com/community/threads/incoming-audio-pausing-during-call.56219/#post-235417 even to the point of saying that we didn't experience this issue until upgrading to 15.5
  • Tried an array of different firmware versions on the fanvils
  • Tried messing with "PBX delivers audio" setting - no effect
My setup...
  • 3CX server installed on in-house Windows Server 2016.
  • Version 15.5.13103
  • Fanvil firmware = 2.4.0.5572
I'm pulling my hair out with this. I made a massive shout about 3cx and how it would be so much better than our old Mitel system, but sadly this annoying issue is casting a dark cloud over it.
At this point, I'm willing to try any suggestions.
Reactions: seegreen
Hello @Gav
The first thing i would recommend is upgrading to the latest version of 3CX which is V15.5.15502.6
How are the phones provisioned to the PBX? Are these local devices or remote?
Phones are configured as local.
I've been doing more tests. The below results are from the exact same phone call...
I dialled a Fanvil X4 from a Fanvil X5 via direct IP calling.
I ran “Web Capture” from the X5. Attached PCAP file 14-9-18-x5
Mean jitter was 0.09ms
Max delta was 20.59
These figures look very good
I ran “Network Packets Capture” from a Fanvil X4. Attached PCAP file 14-9-18-x4
Mean jitter was 40.72ms
Max delta was 1030
These figures are much worse –
Could this indicate an issue on the X4?
Almost like processor overload?
Why would both phones report such huge differences in jitter and delta for exactly the same telephone call?
I can see the issue you are referring to and the fact that this happens on a direct call leads me to believe that the PBX is not part of the issue.
What i am seeing in the capture could either be a network or a device issue as i am seeing some packets that leave the X5 normally and arrive late that the X4.
We do not have any similar reports regarding these phones that is why i would recommend contacting Fanvil support and providing them with the captures so they can look into the issue.
Yes, I'm beginning to lean towards an issue with the Fanvil X4 phones.
The one Fanvil X5 phone I have works perfectly.
I'm currently liaising with Fanvil support.
If and when I get a fix, I'll report back.
Please keep us updated.
So while Fanvil phones are supported, it's been a bit of a mixed bag in my experience. I love the fact that they do some much needed things like LCD screens for BLFs (I hate paper labels) it seems to be a bit of you get what you pay for. Hopefully it's something Fanvil can fix with a firmware update as I know there were issues at the hardware level that could only be resolved by replacing the phones.
Reactions: seegreen
fngl
