Auto import contacts.csv via command line
Sepultura
Forum User
my CRM can export it's contacts to csv. 3CX can import contacts from csv. Therefore I've made a script that converts the CRM csv file to the 3CX format, which works fine so far.
What I need now is doing this automatically via cron job. Is there some command I can run to import the csv?
P.S. a similiar question is here: https://www.3cx.com/community/threads/3cx-contacs-address-book-auto-import.75533/
Have you looked at 3CX CRM integration to see what options you have?
If you mean this one: https://www.3cx.com/docs/crm-integration/
Yes, but there are two problems:
  1. I need support for it on CRM side (which I do not have)
  2. Apparantly contacts are only added on incoming calls. Therefore I cannot search within 3CX for a contact, that has not been added, yet.
You can create new contacts with the 3CX Call Control API.
fransisco
