backup/restore ONLY sip trunks?
dandenson
SOHO User
I'm looking for a workaround. I use VoIP Innovations, they are not 'on the list' so I have to make a rather extensive list of trunks. I'd love to be able to back these up and restore them in a fresh system. It takes me about 15 minutes to manually type these and I'm doing it almost every day so it's become a tedious time sink.
Reactions: YiannisH_3CX
perfect! thanks!
Please note that the option only creates a backup of the providers template which you can use to import to a different PBX. This option does not export the DIDs associated with the trunk. For that you will need to export your inbound rules.
yeah, that's ideal, since you really can't use a single DID on multiple systems unless it's a failover setup.
megalmazan
