Big trouble installing 3cx
Xpsychic
Hello.
Tried to install 3cx from the debian iso on a VMvare instans.
After first attempt, where I needed to restart the installaiton, I never get to the 3cx wizzard.
Have read a couple of threads in here, regarding the same, so Im tryin the backupsolution, to install in manually on a debian installation.
But this also fails...
Im using this guide: https://www.3cx.com/blog/docs/linux-version-9-stretch/
All goes well until my server tries to update the repositorios from the sourcelist added with the guide.
Does not seem to exist anymore?
Is there any change to the sourcelists? any updated guide available?
br
Eivind
Hi, Please get the ISO from here https://www.3cx.com/phone-system/download-links/
I believe you were using a beta version earlier.
Also I have seen cases where the customer's firewall is blocking them, during the installation phase of Debian, causing a failure. You need to talk to your network administrator in this case. If you still believe that the 3CX downloads server is the one blocking you then you need your network admin to run a capture on your firewall and find out whether the request to download ever left your edge router. If if didn't then you have to investigate your end.
My lucky day. My ISP has given me a new public IP and now I manage to install 3cx without any problem. So... My previous IP address were of some reason blocked somewhere at 3cx, preventing me from downloading/pulling image/packages from them.. would be interesting to know why.....
swegner
