Block access the PBX Management Console by .htaccess file
partteam.dev4
I need block access the PBX Management Console by with .htaccess file is possible?
Someone can help me?
Best regards
I believe this is for Apache, but we run on nginx so it wont work.
Why not use the built in Console Restriction instead?
It's under Settings > Security > Console restriction
Just be careful to whitelist yourself so you don't get locked out.
Reactions: partteam.dev4
Why not look at console restrictions under security
Thank you for yours replies.
I already use it, but with thesse configuration the login page show in the same, i want need that page login only show ip of whitelist. it is not possible?
Thank you.
Best regards
No that is not possible. The console restriction will allow the login page to appear, but it becomes useless to everyone except those who are whitelisted. Anyone trying to attack it will unknowingly be wasting their time
Setup an ACL in your firewall.
3K8iMGWviZ
