Bridges - 3CX Pro, Version 16.0.3.525
MH-Nottingham
Running 3CX Pro, Version 16.0.910. I can see bridges on this install. Just done a fresh install for another site 3CX Pro, Version 16.0.3.525 and I cannot see "Bridges" on this install. Everything else seems fine.
11911
11910
What had happened to the bridges option under advance? Need this back.
In v16 SP3, the bridges have been relocated in SIP Trunks where you find also SBC and Gateway.
Can you roll the update back? If so, what are the steps?
No roll back. Either live with it and hope you can upgrade from alpha to beta to final or export (not backup) your settings and do a fresh install on SP2 and import.
You could try to take a backup and restore under SP2 but that isn't supported.
[email protected].
