Solved Bulk extensions via CSV - error
the_jackal_br2001
Forum User
Hey Guys,
I have change the extension number from 8016 and 8017 to 5516 and 5517 and works fine.
So I will re-check the extensions but I did not find any extension 8016 and 8017. May be a service number.
Does anybody knows something?
Tks
I have found the problem after check again...
The two extension were in use for IVR.
That's correct, if you try to import an existing extension it will fail.
Reactions: the_jackal_br2001
EMMEPICASA
