Call drop when press transfer button
sudungthu
Hi, can anyone shed some light on my problem.
When an external call comes in its picked up. an attempt to transfer the call to another extension fails immediately with the drop call.
All the phones are Yealing T29G latest firmware from 3CX.
if any one has any answers that would be great.
Hi cobaltit,
PBX software version is
ProductProfessional
Version Number16.0.910
I was looking for something in forums and testing this problem. Thanks for the reply.
Also make sure that forwards work internally (i.e call your colleague, and transfer them to another colleague). If this does not work, then external calls will also fail when transferring.
However, I would check what @cobaltit said first. If that option is enabled and the provider does not support it they may potentially be dropping the call.
M_R
