Unsupported call duration limite
Erick Moraes
Hi Everyone,
I need a question.
My calls have limite 15 minutes.
But, the parameters SIPPINGPERIOD, MAXNOANSWERTIMEOUT and MAXCALLDURATION have changes.
In contact with my provider SIP Server, says this problem is parameters on 3CX Server.
Have other place for change?
Hi @Erick Moraes,
The MAXCALLDURATION parameter is the only one that will have any affect on the call duration in this case. It's currently set to 3hrs (3 x 60 x 60).
@VasilisV_3CX thank you for feedback.
Yes. this is set to 3hrs. But, the call end 15 minute. Exactly 15 minutes.
where is the PBX hosted? Could be a firewall timeout if SIP ALG is not disabled.
Reactions: VasilisV_3CX
Hi @Frederick Marcoux
PBX is hosted in GCP(Google Coud). Firewalls rules is default when create a PBX.
Hi @Erick Moraes,
  1. What provider are you using?
  2. What version of the PBX are you using?
  3. What type of end point are you using? Is it an IP phone or a Web Client etc?
@VasilisV_3CX
    Advance (link)
    18.0 (build 1880)
    App Android
Hi @Erick Moraes,
Best bet is to run a Wireshark Capture for the entire duration (15 minutes), from a more stable connection (maybe a Web Client). This will show you what is happening in the background (what is being negotiated by the provider and 3CX etc) and should tell you what is happening at the 15 minute mark.
You can call your 3CX Partner to assist in understanding the capture.
laranicole.lucus
