Call Flow Conditions
NephyliaWaifu
New User
'm a beginner with 3X Call Flow Designer.
I want to make a Call Flow able to identify the phone number from the caller and transfer him in the right waiting queue.
I tried to make a simple call flow only for test if the identification of phone number from the caller worked but it doesn't work.
Can you tell me what I make wrong ?
Best regards, Nephylia
I have found the solution, thanks you for the help. No it's a joke, nobody even took the time for help me....
I will never ask help again on this forum.
You should use the Expression Editor to build expressions without errors. This is the expression you need for your case:
EQUAL(session.ani,"0123456789")
Reactions: NephyliaWaifu
Thanks for the reply, yes it's what I have use EQUAL("0033",LEFT(session.ani,4) for filter call from french number, and I made this for a lot of country.
Reactions: edossantos
ARKC
