Call forward using originatorcallerid
Pratt
I am at wits end. I have a DVR set up, with a menu item set to go to an extension. That extension is set to forward to another SIP line.
I would like that SIP line to receive the original caller's callerid.
I have tried and failed with Twilio and VOIP.ms to manipulate the OriginatorCallerID in the From:User Part and From Remote Party
Does anyone have this successfully set up with a SIP provider?
well, basically says to call and ask them....
Anyone had luck adjusting the from user: part with a sip provider?
Finding a provider that supports this is becoming increasingly difficult in the US with STIR / SHAKEN rules as providers are trying to comply and accepting a call with an unknown caller ID to them is not the best.
However you can check out our supported SIP Trunk providers page and find a provider that has "Clip No Screening Support" set to "Yes".
Reactions: KyriacosS_3CX
SG_F7
