Call from a different extension
narkin
I am using ext 222 using an IP phone in my home office, and my office extension is 137. When I'm not in the office I set my desk phone (137) to DND so that it doesn't ring out and disturb others. I have a Forwarding rule set up to forward calls to 222 when 137 is on do not disturb. The problem is, now people in the office are calling 222 as I have called them from that extension before. I'm missing calls because people are going straight to my home office phone and not dialing 137. I'd like to know a way to have my setup, but mask calls coming from 222 as calls coming from 137.
Thoughts?
Thanks,
Nate
Ŵhy not setup both phones on the same extension number, that why both phones will ring at the same time and you can answer it on the correct phone depending where you are
I'd like to avoid having the other ring if at all possible
bosdorf
