- Joined
- Oct 7, 2019
- Messages
- 134
- Reaction score
- 13
I'm having issue with the bridging.
Im getting this error when I tried to call outside numbers via the bridge
Here's the Scenario:
Testing and result
1.Called outside number from cloud extension = working
Scenario 2:Reverse setup
Any clue on how should I troubleshoot this one?
Note: It's our first time setting up 3CX
Thanks in advance
- Local and Cloud PBX bridged
- Local PBX on has Bridge trunk configured
- Cloud has sip trunk (mvoice) and bridge
Testing and result
- Called extensions between bridge = working
- Called outside number from local = not working
- Number called from Local reflects in the cloud but with error
- Add the mvoice trunk in the local pbx and remove it from the cloud
- All test results are positive.
Thanks in advance
