Call out rings once then cuts off - Voicehost UK
fincomp1
I have a trunk configured with Voicehost in the UK. Calls in are fine but when I try to call out it rings once and drops. This is for all extensions.
Outbound is chargeable so there might be an accounting or activation issue there.
Can you please contact your provider first and see if they can give you a reason for why outbound calls drop?
I have spoke to the provider and there is no sign of it hitting the system. The trunk works on a standard 3cx system both ways and is showing as activated on the system. There does not appear to be a routing option on the free service but I assume it's because you can only have one trunk.
Hi @fincomp1
I will send you a p.m so we can investigate further
lonedigger
