- Joined
- Nov 8, 2010
- Messages
- 101
- Reaction score
- 28
This link:
https://www.3cx.com/docs/manual/departments/
says this:
I have three Users in a common Department (Testing).
If User One is given ANY or ALL of these permissions: "Show My Calls, Barge/Whisper, Presence, Operations,"
when User Two calls User Three,
then User One CANNOT pick up that call period.
If User One is given these particular permissions: "Presence, CALLS, Operations,"
then User One CAN pick up that call
but ONLY if
User Three has "Show My Calls" turned on for that common Department (Testing).
In the same scenario, if User Three turns around and calls User Two,
then User One CANNOT pick up User Two's ringing phone if
User Two does NOT have Show My Calls turned on.
This doesn't seem to make sense based on what I'm reading.
The problem here is that we do NOT want to turn on "Show My Calls" and let everyone see the actual numbers that people are calling. We simply want OPERATIONS (!) to work.
Is this a bug, or is this how it is intended to work?
If it is not a bug, how can we allow Users in a common department pick up each other's calls without SEEING the number that each User is calling?
Updated to note: It does not matter if the Testing Department is the Main/Primary group for each User. If Show My Calls is not selected for User Three, then User One still cannot pick up his calls.
Updated to clarify question(s):
says this:
However, in reality, this does not SEEM to be the way these rights work in the current v20 beta (786).Restrictions can be applied as follows:
- Presence - User can see status of all users that are a member of that group
- Calls - User can see all calls in that group
- Operations - user can perform operations such as call pick up on calls of that group
but ONLY if
- Why can't a User in a Department who has "Operations" selected Pickup calls unless that User is ALSO given the "Calls" permission? [Calls also requires Presence permission.]
- Why can't ANY User in a Department who has "Operations" and "Presence/Calls" permissions turned on Pickup calls unless the TARGET User has "Show My Calls" turned on?
