Call Processing Script - Multiple Script assign to one ressource
nicolasGa
Titanium Partner
Is there a way to assign several script to one ressource (Trunk / DID) ? And maybe have an order for each script associated.
If not, is this something that is planned for near future ?
Thx,
I’m not sure I understand your question. If you need to use multiple scripts, you can simply structure your code within a single script by dividing the logic into separate methods, which can be executed in a specific order.
Could you elaborate on your requirements?
Can you share an example scenario?
Seems like you understood my question even with my poor english TT.
Yes I can do all this in a single script, but it would allow me to have better organization of my several scripts.
For example, I have a script that can handle holidays (fetch a specific API to have the holidays in the year) + some actions depending on the caller and so on...
Also, do you know how to get all the departments name, user name and so on through a script (other way from a get of the API)?
Thx,
tom.walker@blackcountryra
