- Joined
- May 18, 2023
- Messages
- 19
- Reaction score
- 6
A couple questions ringing of incoming calls to a Queue, and dial delay on outgoing calls.
Setup:
In attempting to resolve I did the following:
Anyone have any answers. Why so much issue when using a Queue?...again 2 separate instances having the same ring problem with a Q.
Side question...
Is there a parameter that controls the delay after dialing the a number:
Lonnie
Setup:
- Office Hours...Assigned Incoming DID
- Office Hours...Office Open...Route Calls to Call Queue
- First, verified that issue did exist...I called in...heard one ring...then silence.
- So then, from M.Console...Edit Queue...scrolled down to Music on Hold...it was set to onhold.wav.
- I clicked Manage and performed a Playback to my extension.
- Hi Ok to exit Queue.
- I dialed in and it rang once, then started playing MOH music (onhold.wav)...this was different than before I hit the Manage butt.
- Then, in the Q, I changed the MOH to USProgresstone.wav.
- Now, after dialing I hear continuous ringing...note I can hear a different between ring 1 and ring 2...assuming the .wav file has kicked in.
Side question...
- If you 'get a line' or pickup headset or speaker before dialing number, phone will dial a couple seconds after number entry...this is too short a duration.
- Dial number without picking up handset or speakerphone (using this process more time is available, phone actually doesn't dial, but returns to wait state)
- Up to 15 seconds before phone will return to waiting state
- After dialing, then pickup HS or SP, call will be dialed immediately
- Using Yealink T57W phones.
Lonnie
