CALL QUEUE DISTINCTIVE RINGER
sonnyh1
SOHO User
I have several Call Queues setup for various purposes.
How can I set a distinctive ring for each of the queues?
The phones in the system are X5U, X6U, X2U, and Yealink W70B
Hi @sonnyh1 you can set a separate ringtone for the queues.
To do so, go to the pbx management console ---- phones --- options ---- select Use custom ringtones per queue. Note: Each agent will configure distinctive ringtones for the queues. Non configured queues will play the ringtone used for normal calls --- apply the changes.
Then edit the user that is part of the queue --- phone provisioning --- and you will see the following field: Specify a different Ringtone for a particular Queue
Set the custom ringtone for each queue:
Have a nice day!
Reactions: IrinaP_3CX
Thank you.
Is there an easy to preview the available ringtones?
no, you will need to provisioning and test.
Thank you.
That would be too easy:)
you are welcome, have a great week ahead!
Reactions: jed
