Solved CalledNum on caller ID
Optical Conclusions
Is there any way to display the dialed number on incoming calls when they are ringing mobile simultaneously. If i prepend it under contacts settings, it dosn't show up on the cell phone, only on physical phones. Cell phones only shows the dialer number.
The Rin My Mobile option is actually an external call from the PBX, so the sip trunk number will be shown.
I know but Interestingly the callers number shows up not the sip.
Which provider? Also have you made any change to the outbound parameters?
Im using telnyx as sip provider.
I fgured it out,
I set outbound parameters "From : User Part" to "OutboundCallerId".
This worked. Thanks for you help.
Reactions: TheodorosG_3CX
You are welcome ;)
cur_cb
