Caller ID Reformatting - missing patterns
ZoloN
hi all,
playing around with CID reformatting I've realized, that I miss more advanced patterns (e.g. for non-zero number) like the Asterisk does:
Code:
X   matches any digit from 0-9
Z   matches any digit from 1-9
N   matches any digit from 2-9
[1237-9] matches any digit or letter in the brackets (in this example, 1,2,3,7,8,9)
/BR
ZoloN
Can you provide an example of what the originating caller ID is, and the desired, final result?
hi leejor,
nothing in particular, I've solved my needs. just missing the above mentioned pattern chars ;)
/BR
ZoloN
hi JohnS,
thanks, I'm familiar with them. and as I wrote, I've already solved my needs. this was just such a public " I Wish You Were There"... :cool:
/BR
ZoloN
DrunkeMeister
