Can not connect SBC with PBX
SonDuong
Forum User
Hi all,
I have a problem when connect SBC on Pi 4 with PBX v16, I added SBC on PBX v16 and installed SBC on Pi 4 but it doesn't work
However, I tried install SBC on window and it success.
So what happen with SBC on Pi 4 ???? Please help me fix.
On the PI check your dns settings, change to google 8.8.8.8
Test to see if the PI can resolve your 3cx fqdn and it has the correct ip address
Reactions: AWS2P
Yes, I checked, it's correct
This indicates that the SBC most likely:
1. cannot reach the PBX (internet connection or misconfig)
2. cannot resolve the url to your server IP
Possible solutions:
  • You can try reinstalling the Pi SBC from scratch https://www.3cx.com/docs/installing-pbx-raspberry-pi/
  • You can check to see whether the Pi actually has internet access
  • If the PBX only recently came up it may take a few minutes for the DNS to resolve. This should no longer be a problem now
Possible solutions:
Hi John,
1/ My Internet good working
2/ I set DNS name server 8.8.8.8 and nslookup my URL, it's resolved correct IP.
We have 1 server 3CX test using standard license and I registered SBC with server test, it success. But when I register SBC with main server 3CX using Pro license, it not success.
If you registered the same SBC on the test server, then we can assume for now that the SBC is ok.
  1. Where is the Pro server located? (Local / Cloud)
  2. Where is the SBC located (same local network as the PBX or remote network?)
  3. On your Pro server, is tunnel port (5090 by default) still open over your firewall?
Reactions: AWS2P
