Can V20 support multiple fax lines yet?
ehas
SOHO User
Currently stuck on V18. I have multiple DID's for the fax server, which go to different email addresses. The last thread I can find states this is no possible. Can anyone provide an update please?
Yes, you can add fax lines to every extension you like.
Reactions: N_G
In addition to the fax extensions, where you would define an extension for an analogue fax machine, you can also create a fax forwarding rule, where you can select a DID to send the incoming fax to a users email.
Here extension 880 was created to be able to hook up a fax machine to an analogue FXS gateway, and extension 100's email used as a fax forwarding when the fax DID is used.
Reactions: bitn2 and JohnS_3CX
Syedx91
