Solved Cannot connect to 3CX management console (also)
TLCtech
I just spun up a 3cx server on my Raspberry Pi4 but I cannot get to the management console. Ive redone this install 3 separate times. All with the same issue. Once its done, it gives me 2 urls, and neither work. Ive also tried using the local ip:5015 to access and it wont either.
I started following the directions in this thread, but I cant connect via the local ip.
https://www.3cx.com/community/threads/cannot-connect-to-3cx-management-console.58579/
nslookup doesnt work. At all. It just gives me a > symbol. I have a static IP set for the pi.
  • 3CX Version, not sure. I downloaded the latest one from wget
  • Server OS, Raspbian GNU/Linux 10 (buster)
  • Is the 3CX Server Hosted and where? Locally Hosted
I have not even gotten to these questions yet
  • IP Phone Make/Model/Firmware
  • Provisioning Method: Local / VPN / STUN / SBC
  • Trunk Provider or Gateway Make/Model
  • Has the Firewall Checker passed: YES / NO
  • Are custom Phone Templates being used: YES / NO
Thanks in advance
I apologize. That wasn't clear. Yes, I got through the set up, and was given the two urls.
And I don't know why, but I think it had something to do with the ports. We went through and opened all the required ports and suddenly it worked inside and outside the network.
:shrug:
footandankle.my3fcx.us
