- Joined
- Mar 25, 2020
- Messages
- 23
- Reaction score
- 4
When a caller calls into our system all they hear is "Sorry, the number you called was busy", and nobody is on the phone.
I have been searching online for hours and not having much luck. I cleared my activity log and called in once.
Our system is hosted on google platform with a static IP. It worked yesterday. Outgoing, and extension to extension work. This only seems to bother the inbound calls.
The DID at the moment is set to connect to an extension for simplicity, it still fails.
I have followed all the guides but i must be missing something. Anyone have a suggestion?
Below are partial logs from the call.
| 03/25/2020 6:12:12 PM - Default best-route IP is determined as 10.128.0.2 |
| 03/25/2020 6:12:08 PM - Updating device Dev(1227963009):[sip:[email protected]:5063;rinstance=2418f8d488b61d24 / 90000] by message: DevUpd Recv Req REGISTER from 127.0.0.1:5063 tid=7a66ab18e338b236 Call-ID=eHpXZKKI3h9w4zQYHiy3fQ..: REGISTER sip:127.0.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 127.0.0.1:5063;branch=z9hG4bK-524287-1---7a66ab18e338b236;rport=5063 Max-Forwards: 70 Contact: <sip:[email protected]:5063;rinstance=2418f8d488b61d24> To: <sip:[email protected]:5060> From: <sip:[email protected]:5060>;tag=bd2d9773 Call-ID: eHpXZKKI3h9w4zQYHiy3fQ.. CSeq: 426 REGISTER Expires: 60 Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE Proxy-Authorization: Digest username="90000",realm="3CXPhoneSystem",nonce="414d53595e7bd73791:ad69f41dc7eb67624eceb2b6186a87dd",uri="sip:127.0.0.1:5060",response="7215f74ab5110fe5f142472241e739f6",algorithm=MD5 Supported: replaces User-Agent: 3CX WebRTC proxy Content-Length: 0 |
| 03/25/2020 6:12:08 PM - Line 90000 got Device: Dev(1227963009):[sip:[email protected]:5063;rinstance=2418f8d488b61d24 / 90000] |
| 03/25/2020 6:12:08 PM - Source is identified as trunk Lc:90000(@WebMeeting bridge[<sip:[email protected]:5063/UDP>]) |
| 03/25/2020 6:12:07 PM - Source is identified as trunk Lc:90000(@WebMeeting bridge[<sip:[email protected]:5063/UDP>]) |
| 03/25/2020 6:12:01 PM - Default best-route IP is determined as 10.128.0.2 |
| 03/25/2020 6:11:58 PM - Currently active calls [none] |
| 03/25/2020 6:11:56 PM - Timezone offset: -240 min. |
