can't access 3cx server from WAN
rubennazarian
I have set up my 3cx server on a windows machine.
I am only able to access the server from LAN
I can't use public IP or FQDN
I'm running it behind a Mikrotik router. when I run the firewall test everything checks off.
what should I do ?
to see ports listneing and really open on windows
just open cmd and run netstat /? for help
@rubennazarian
If you go to another internet connection (from your home internet for example or via mobile internet) does the FQDN work?
It’s open
433 TCP
UPDATE
I changed to the server to a Linux based one but I still can't access it
anyone knows why?
anyone knows why?
If there is an issue with you firewall blocking the access to the management console then changing the operating system will make no difference if you are still behind the same firewall. You need to troubleshoot the issue by looking into your firewall. If you do not know how to do that then perhaps it would be beneficial to contact a 3CX partner to get some assistance.
hughesdouglas
