Solved Can't Access Clients Management Console
Ritech Computing Services
I'm currently setting up a new client with 3CX, I have added my client through my own portal "ADD CUSTOMER" Button and connected my Partner ID. Now that it is installed I can see the system, but can only access the WebClient, and not the Management Console.
My question is: How do I access my clients Management Console to be able to configure my SIP Trunk and other configs?
Have you created 3CX Hosted or a 3CX StartUp?
If it is the later, then you get access only to the webclient and you configure it.
Please check 3CX StartUp guide.
Okay I see where I made my error.
How do I Delete this system ? or any in general, I cannot find the option to DELETE a system.
Only the owner of the key can delete it from his portal.
When you go to My Systems , click on the specific system and on the next page you will see the delete button.
Have in mind that you can run a new 3CX Hosted system and then delete the 3CX StartUp.
mazet
