Can't Get Inbound Calls to Work
AtlasCyber
New User
I am a new user of 3CX. I have a SIP trunk from DIDLogic.
I have gotten outbound calls working, but for inbound calls, the phone rings once and then states that I have reached a non working number. I have setup an inbound rule (pictured below). The 3CX phone log shows no record of the incoming call (nor does DIDLogic), but they do show the outgoing call record.
I don't know if this is an issue with DIDlogic or 3CX. I would appreciate any help or guidance you may have.
Thanks!
If DIDLogic doesn't see the inbound call I'm not sure why you think 3CX would. You definitely need to work with DID Logic for this.
Hi @AtlasCyber,
As @cobaltit mentioned, if your SIP Trunk provider isn't registering the incoming calls, then this wouldn't be a 3CX issue.
Did you port numbers over to DIDLogic or are these provided by them?
jmarshall
