Can't get it to work with zoho CRM!
Masaya Hanato
Hi, I have installed 3CX on AmazonLightsail.
https://my-pbx.example.jp:5001
but the connection is refused when I type
I have registered it at
Here is the problem I was able to get to the approval screen without any problems, but the green mark of approval is not lit.
Maybe that's why zoho and 3CX are not working together either: the API access logs are kept on the zoho side, but the 3CX side shows that the search feed is not turned on. (It is set up correctly on the zoho side)
Can anyone help me solve this problem?
Please let me know and I will try to fix it.
Translated with www.DeepL.com/Translator (free version)
jasonkkrause
