Can't listen in on some "Q"'s
VictorC
SOHO User
Hi all, I have a client that has like 6 "Q"'s and some you can use the listen in feature and others will not show it. All people that want to do it can listen in on some of the "Q"'s but not all and they are all setup the same. I'm at a loss to why.
Anything I should look into?
Look into the Groups, all your extensions is not member of the same groups, or some of the extensions are users and other are managers. There is a specific selection for listen and barkin
Reactions: NickD_3CX
Thanks, I overlooked the groups :) they needed to be added in each of those.
Reactions: NickD_3CX and jed
K7oR0x
