Can't modify/edit an existing SIP-trunk after upgrade
schut
Upgraded from V18 to V20.0 Update 6 (Build 724 Release) today.
I have an existing SIP-trunk (which is working..) which I can't edit in the Admin-section under Voice&Chat
I have 5 SIP-trunks, and all I can modify but except this 1 which is.. obviously our main one.
Whenever I press the 3 dot's behind it and press "Edit Trunk" the web-browser returns to the 3CX Teams overview with all my extensions.
I've tried 2 browsers and 2 different users who have access to modify SIP-Trunks.
Are you able to export/import the trunk?
I can export, but I'm unable to find an Import-button. Also, not sure if it will overwrite "all" settings from the one I can't edit, it has loads of DID's assigned to it which I rather not redefine and those are not stored in the exported XML file, it seems...
This happens if the trunk template does not exist in v20.
Hello ,
please check the: Admin - Reports - Inbound rules.
You should see a list of DID numbers that are in use.
Paulo
arming
