CFD - Office Hours & Out-of-Office Hours
Maurice Lefevere
Gold Partner
We have been using the CFD for quite some time now.
Some of out PBX'es have been upgraded from v18 to v20.
In v18 we had setup out office hours. Working like a charm.
When upgraded to v20 they seem to work nog longer.
When i setup a opening time like 08.00-12.00 everyday and on the CFD i choose 3CX Office Hours it doesn't work anymore.
The CFD only checks for opening/closing times and depending on that transfers it to a "Call handling" part on v20.
What am i missing here?.
Department bound for the CFD app?
There is just one department; DEFAULT.
On the Call Processing Script page the CFD is set to "System Wide" so i quess that's not the problem?
That's the problem. There are no system wide times anymore. They are all tied to departments.
Tie the CFD program to the department and the time control should work.
@fxbastler
Hmm i changed the department, but that doesn't fixed it.
You're right. It doesn't seem to work with the current v20 u2 anymore, I just tested it, just for you.
It worked with one of the previous v20 versions. I'll have to try and see what's different now. Maybe someone else can say something about it.
Appreciate it !!
I'll hope this gets fixed quick.
Reactions: Rogé
it works like a charm, again, tested it ...
Thanks.! I've changed "Office Hours" to just day and time for now. I can't make these changes for +60 PBX'es and hope it will work one day ;)
amazingbv
