Change accountnames in 3CX windows phone
telforce
When i add a new account with the provisioning files i get from 3CX to my windows softphone it uses the name of the PBX to describe the account. So when i switch accounts i see these PBX names and i can't change the description. I have 3 PBX accounts on my phone and their names are very similar. So i was wondering if i can add a line to provisioning file where i can give each account my own custom description?
Hi @telforce
It takes the name from your extension. Simply edit your extension name to include something that helps you tell them apart, like a character or a number for example.
12864
In direct response to your question, no you cannot add a line in provisioning to affect this.
What i mean is the second part where it displays the name of the PBX.
12872
Hi telforce
No that can't change because it's not actually a name label. It's literally the FQDN of your server.
But lets say i add a suffix to my last name in the extension, won't callers see that too when i call them?
Yes, it will appear. I'm not sure if there is any solution for what you want unfortunately other than keeping it as it is now.
Thanks for clarifying, i think i will just place my fist and lastname in the firstname field and use company name in the last name field.
Reactions: AWS2P
Not a bad idea actually :)
Wecare_ITA
