Change forwarding number via XAPI
JulienM
Platinum Partner
I would like to be able to change the call forwarding numbers for each status using XAPI. Unfortunately, this type of action calls an ASMX web service with an encrypted payload, so I cannot reproduce this request. Have any of you found a solution ?
In the example below, I modify the forwarding of internal calls to number 100 for the "Away" status :
T2T
