Change LAN-IP Address
Sommer
Intermediate Cert.
Hello.
A customer decided to change his LAN-range.
Do I still need to make a backup and reinstall 3CX? I've read somewhere that I can just change the local IP and restart the services?
3CX V15.5 on Windows.
Thank you very much.
Best regards,
Sommer
In v16 this can be done from the WebInterface, as the customer needs now more or less reinstall to change the IP in v15, best to perform the upgrade in the same run.
Note: https://www.3cx.com/docs/manual/
Note: You may switch the customer with an existing backup also to a Linux based install.
Reactions: Sommer
Okay, thank you for the information.
Best regards
Wecare_ITA
