Change port 80 on V20 Insttallation
sotrix
Hello, someone have installed V20 on different 80 web port?
On my local server, this port in used by local webserver
The PBX server must be a dedicated machine as this can cause other issues as well.
@sotrix
When you install the System, you have an XML file and in there, you can specify the local port of the system.
If you want to go with this option, feel free to do so, however, keep in mind that 3CX system should be dedicated as per our manual (no support can be provided in case something is wrong).
@sotrix
What about dedicated machines behind NAT? A premise customer with an SSL VPN router/firewall loses functionality when 3CX takes ports 80 and 443 in the NAT.
NAT is fine. All clients will use the configured port number.
Indeed, you can choose any not-used port.
Keep in mind that as per our admin manual, we don't support OS running 3rd party applications VPN, DNS etc and you might face unpredictable issues of which we are not aware as it's not tested.
Carlos - EC Mates
